I wouldn't worry too much about the weight side of things. Quite likely they'll still be a bit less than the Suzuki rim (vehicle manufacturers tend to go for strength over light weight as they don't want to be replacing rims under warranty.)SuzukiGirl14 wrote:I decided on a wheel, but unfortunatly it is heavier than the stock rim. I couldnt find the exact weight of the 17" alloy rims but these new wheels have an average of 25. As mentioned above, I'm not trying to spend alot of money but these wheels have been the only ones that I truely liked. Will this be a major issue on my car?
Ideas for Wheels???
- 11zukizashi
I am reffering to 2011 and 2012 cars not 2010. Both 18.murcod wrote:You're also comparing 17" to 18" wheels between SE and GTS
About the sidewalls... if you had read my post I acknowledged the irrelevant drag strip stuff:
11zukizashi wrote:unless your car produces enough torque to use the tire as a launch spring.
Traction off the line irrelevant in a front wheel drive Kizashi? Mine will spin the wheels without too much provocation, I'd much rather it didn't.
Anyway, back to wheels choices. I think the aesthetics are possibly a high priority in SuzukiGirl's wheel options, not outright performance? The info is there to help (or hinder?!) any decision.
^^ What is the make/model of those rims? Was looking at the Sport Edition F10 with black accents, but I like those better.
- se_f10_mfba_ci3_l.jpg (22.84 KiB) Viewed 7099 times
Here are 16" purchased mounted from Tire Rack - I posted these pics here a year or so ago. Going from 18" stock to 16" with snows made quite a noticeable difference in steering response. Sure, when you hit the pothole with the bigger sidewall of the tire on the 16" wheel you have a better cushion. But with the 18" you can steer around most of those potholes. You have great precision. It's a tradeoff on the steering response, to be balanced with looks, weight, cushioning, and price.
Your experiment is confounded by having two entirely different types of tires. In your experiment, there is no way to determine if the lack of response is due to the section thickness or the soft compound and siping.chazyouwin wrote:Here are 16" purchased mounted from Tire Rack - I posted these pics here a year or so ago. Going from 18" stock to 16" with snows made quite a noticeable difference in steering response. Sure, when you hit the pothole with the bigger sidewall of the tire on the 16" wheel you have a better cushion. But with the 18" you can steer around most of those potholes. You have great precision. It's a tradeoff on the steering response, to be balanced with looks, weight, cushioning, and price.
