2010 to Pressent Fluid Specs
Engine Oil
◾Type: API Approved "Starburst Symbol"
◾Viscocity: 5w/30
◾Capacity: 4.5L (4.8qts)
Engine Coolant
◾Type: Suzuki Super Long Life Coolant
◾Capacity: 6.6L (6.9qts)
Automatic Transaxle (CVT)
◾Type: Suzuki CVT Fluid Green -1 or Shell Green 1V
◾Capacity: 8.34L (8.8qts)
Manual Transaxle
◾Type API GL-4 Gear Oil
◾Viscocity: 75w/80
◾Capacity: 2.5L (2.6qts)
Transfer Gear Box (AWD)
◾Type: API GL-5 Hypoid Gear Oil
◾Viscocity: 80w/90
◾Capacity 0.9L (0.95qts)
Rear Differential
◾Viscocity: 80w/90
◾Capacity: 0.9L (0.95qts)
Refrigerant
◾Type: HFC R134A
◾Capacity: 530g (1.16lbs)
Fuel Capacity
◾Capacity: 63L (16.6 US gallons)
Very helpful. Thanks.
I saw this same helpful list on suzukihelp.com. 8-)
...just thought I'd put it on here since we get a lot of 'what oil, etc.' posts from time to time. Now it's all in one place on the forum.
Ronzuki wrote:...just thought I'd put it on here since we get a lot of 'what oil, etc.' posts from time to time. Now it's all in one place on the forum.
Sticky this?
I was hoping to find the fuel capacity. :( That's the one thing they left off!
SamirD wrote:I was hoping to find the fuel capacity. :( That's the one thing they left off!
63 litres. I'll let you convert that to US gallons. :)
16.6428 according to google. That's a pretty good sized tank. I had "---" for the range yesterday when I filled up and it was only 13 gallons, so I had 3 gallons in reserve. Good to know. 8-)
That reserve may not always be the same from fill to fill. I have no way of backing this staement up, but I believe the range changes based on how long (miles) you've driven since the '---' appears. Hence it dials in the range better so next time you may have 1 or 2 gallons left.
Yep, I kind of expected that's the way it works. I'm sure the fuel light works off a different sensor as I've noticed that in most cars. I usually watch that versus any range information. But it was surprising that there was almost 3 gallons left when the light came on. That's almost 100 miles if you really feather it on the highway.
