I'm thinking of replacing the stock footwell LEDs to red ones so they better match the rest of the interior. Does anyone know what type of LED is used? None of the online references nor the owner's manual list it.
How keen are you? You could cut the loom and join a red LED onto it (remember you'll need a suitable sized resistor in series) or look into disassembling the module.
murcod wrote:How keen are you? You could cut the loom and join a red LED onto it (remember you'll need a suitable sized resistor in series) or look into disassembling the module.
I'm thinking of it. I have the LEDs, bulb holder and resistors from when I added ambient lighting to my GTI. All I'd have to do is drill a small hole in the panel for the new LED and tap the existing wiring. I'd leave the stock LED unplugged
Here's the driver side panel with the new LED in. There's a nice flat spot right next to the stock light. I used wire taps on the stock wiring for power (white is +, gray is -).
The use of LED holders allows me to simply pull the LED out when I remove the panel in the future.
No finished pictures but it's pretty much the same as the stock light but red.
