SamirD wrote:He showed me a genuine Suzuki oil filter and showed me how the design of it is different than other Suzuki filters that fit. And that design is key if you planning on keeping the car forever as it keeps the car from dry starting for about 1/10th of a second. If you're using an aftermarket filter that doesn't have this design feature, you may be causing some premature wear.
Did you get a part number for the filter? I believe there are multiple OEM filters but only 16510-61A30 is made in Japan. Other OEM filters are made of lower quality materials (cardboard endcaps, etc) in China and Austria. Also, what you're describing sounds like an anti-drainback valve, which many aftermarket filters have. Correct me if I'm wrong though!
Steve sounds like a very knowledgeable guy! He would be an asset to the forums *hint hint*
bootymac wrote:Did you get a part number for the filter? I believe there are multiple OEM filters but only 16510-61A30 is made in Japan. Other OEM filters are made of lower quality materials (cardboard endcaps, etc) in China and Austria. Also, what you're describing sounds like an anti-drainback valve, which many aftermarket filters have. Correct me if I'm wrong though!
I didn't but I vaguely recall the end of the number had a "v1". I searched on here to see what the part number is for our cars, but didn't seem to find it. A thread here talks about the differences between the two part numbers for an sx4, which may have a similar design to the Kizashi:
http://www.suzuki-forums.com/suzuki-sx4 ... art-s.html
I'll have to bring up that part number with him the next time I see him. What are all the part numbers for our oil filters?
He would be a real asset to the forums for sure, but unless he's going to get more sales, I don't know if he'd really be inclined to contribute. After all, it's this knowledge that brings people back to him to service their Kizashis.
SamirD wrote:Went to Ray Suzuki (Chevrolet) and met Steve the service writer and gave him the wheels for warranty repair. He quickly had them check the rear shocks and he confirmed that they're both corroding in the same place he's seen damaged ones. Parts are on order. 8-)
So he and I got to talking about Kizahis since they used to stock 100 when they were a dealer and in his estimate sold almost 2000.
Common issues he's seen--headlight bulbs, alignment-induced tire wear, rear bump stop related shock damage, paint flaking from the wheels.
Not so common--only two transmissions replaced ever, and one was just making a whining noise. Three water pumps, which seems even a bit odd to him.
He showed me a genuine Suzuki oil filter and showed me how the design of it is different than other Suzuki filters that fit. And that design is key if you planning on keeping the car forever as it keeps the car from dry starting for about 1/10th of a second. If you're using an aftermarket filter that doesn't have this design feature, you may be causing some premature wear. I listened carefully this evening when my wife started the car. I think I've got a little bit of that going on. I've noticed some extra noise from cylinder 2, but don't have my scope to listen acutely and pinpoint it.
I asked him all sorts of questions like what we've discussed here in many of the threads. He has a BOOKLOAD of knowledge on the car, and was freely sharing it. Maybe to get some repeat business, but I think he also is a fan of the car and the owners.
I asked him how busy they stay and because they're one of the higher rated Suzuki service centers in the nation as well as one of the only ones in a 250mi radius, they stay pretty steady at all times, which is great for them and us. What was really interesting was that they even had a small Suzuki sign still on the building. :)
I even asked him about the HID swap, and he mentioned that in theory it sounds like it would work, but to not think that I won't have to buy bulbs as he's even seen HID bulbs go out. I think he was referring to a lot of the cheap HID kits we know to avoid.
He had an interesting perspective on the car and aftermarket goods. Most any intake messes with the idle. Almost any electrical add-on like HIDs or even the wrong type of tint will make your AM signals go out. He's got a vast database of these oddities about the Kizashi in his head.
I have to return to pick up the wheels when they're done as well as get the rear shocks and bump stops replaced. If anyone has any questions that they'd like me to ask, post them up! I forgot to ask him about tpms issues, so that's on my list already. 8-)
Great info. Thanks.
As for the filter, I agree with bootymac that he's talking about an anti-drainback valve. These are not rare at all if you get high quality filters like Mobil 1, Purolator PureOne, etc. They are clearly visible when you look at an oil filter.
The reason why they matter for the Kizashi is because our oil filters are mounted sideways. They are not necessary for filters mounted opening upward.
Below is a picture of the very Mobil 1 oil filter I use. It's actually the one specified for the Kizashi (M1-103). See the orange thing behind the round holes? That's the anti-drainback valve.
Below is a cut-out diagram of a Purolator PureOne oil filter. It too features an anti-drainback valve.
I have no doubt these filters are superior to OEM Suzuki filters even from their filter media alone. Not saying OEM filters are bad, but you really don't need to go out of your way to get OEM filters when auto parts stores sell better filters that have these features. It's nothing proprietary to Suzuki's filters for the Kizashi. However, a better filter like a Mobil 1 costs more money. For me, it's a convenience matter to get an aftermarket oil filter vs. an OEM one. The fact that they are also better is a bonus.
Interesting that HID kits can affect AM radio signals. I've not tested it out because I don't listen to the radio much, even FM. I was already aware of tints affecting radio reception, but that all depends on the type of tint.
I will see if my AM reception is poor, but I know my FM works great. I personally hate talk radio so would never use my AM radio unless it's an emergency situation like an earthquake or evacuation.
Also, OEM HID bulbs go out, especially when they age. I see cars with OEM HID bulbs out all the time on BMWs, Lincolns, Mercedes, Toyotas, etc. You can always buy a new bulb and replace it. You can get them aftermarket so it's not a really big deal.
That being said, I'd still get an aftermarket kit so I can use the existing headlight. You get the best price performance this way.
murcod wrote: Kuro, halogen bulbs are cheap! In over 20 years of driving I've only had to replace 2 sets because they've actually blown. I'm sure people who do more driving at night have other experiences, but it isn't going to send anyone bankrupt compared to the cost of a new LED headlight.
Halogens are cheap indeed and get the job done, but don't actually emit light optimally. LED and HID bulbs actually cast usable light further and also better reflect light from reflective materials like road signs, safety vests, etc. I've noticed this myself with my LED and HID bulbs. You can see signs much better from further away.
Also, as our Kizashis exemplifies, changing the light bulbs in cars are getting more difficult due to more condensed engine bay designs. Implementing bulbs that have longer life if not replacement-free designs would be good.
LEDs basically last the life of a device because of their long lifespan. While I will not say they are completely fail-free, they will last a lot longer than halogens while delivering more consistent performance over their lifespan. Halogen filaments burn out gradually and that's why they get dimmer and dimmer over time. We've all see older cars with headlights that are very dim. I'm not talking about UV haze as many older cars have glass headlights. It's the actual halogen bulb's filament that's worn out.
While LED headlights may seem gimmicky, I think it's a step in the right direction as lighting is directly correlated with safety. Also, I've seen many 2014 Corollas on the road with these LED low beams. They work well and look like softer HIDs. I have no doubt the rest of the industry will follow Toyota's lead and will offer LED headlights as standard in the near future.
I'm still unsure of all the different OEM filters out there. Further research seems to indicate that only 16510-61A31, which superseded 16510-61A30, is intended for the J20B and J24B (Kizashi's) engines. I believe both 16510-61A30/31 are made in Japan. My invoice for my last oil change indicates that 16510-61A31 was used.
I checked my oil filter part number a while back (OEM from factory) and the part number was 16510-61A31 .
I came across this list when searching the part number for the Suzuki OEM filter. This list could be useful and I will post it in the thread on oil changes.
http://www.oilfilter-crossreference.com ... 6510-61A31
krell
This is where the cops say the bullet hit the car... also where can i get this molding i search all the dealers site can't seem to find the molding
krell wrote:This is where the cops say the bullet hit the car... also where can i get this molding i search all the dealers site can't seem to find the molding
I've seen them sold as an accessory, but didn't the bullet also damage the door? Did the police recover the bullet as evidence?
I'm thinking that if the bullet damaged your door, shouldn't insurance cover that assuming you have full coverage?
Regardless, here's something. However, the picture looks different than the factory ones on the Sport models. You might need to call and make sure they are the same.
http://lehmansuzukipartsonline.com/part ... logid=5512
