adub94
Took off the wheels and painted all brake callipers red. Loving the result!!! :D
adub94 wrote:Took off the wheels and painted all brake callipers red. Loving the result!!! :D
Pics!
adub94
see attached
honsonwong
Looks great!
alwayscjb
Kiki (that's her name) and I do outside sales for a tech company.
So we called on customers and made some money.
sx4rocious
Filled her from 1/4 tank to full in Indianapolis last night for $10 @ $1.79 a gallon!
Yesterday, I went hiking in rural Virginia and took the Kizashi to get out there. I drove a bit spiritedly around the mountain and noticed some brake fade. I recall others here talking about it with their OEM pads.
On the way back, I filled up the tank with Regular costing only $1.99 a gallon. :shock:
Today, I finished up the LED conversion by installing the rear license plate bulbs.
twonotrump
i came home turned off the car went inside 4 hours later went to garage and heard something
runninng got key and started and turned off car again and whatever was running stopped this happened once before any ideas tu
twonotrump wrote:i came home turned off the car went inside 4 hours later went to garage and heard something
It's the leak detection pump. Most new vehicles have it now. From the owner's manual:
LEAK DETECTION PUMP
Your vehicle has a pump to regularly check the vehicle's evaporative emission control system for leaks. This check is performed approximately 5 hours after the engine is turned off. During this leak check, you may hear a sound coming from the vehicle for several minutes. This sound is normal and does not indicate a malfunction.
twonotrump
o k thank u i will pay attention the next time to see how long it stays on
