Hey, good people.
I recently registered to the forum.
I got my Kizashi in July and I just love the car so far. I found it by chance, browsing the ads.
Had never heard about the model. Just typed in what I was looking for in options and how much I wanted to spend. And there it was...
Anyway, I was wondering about the wheels...
I have some original Suzuki wheels on it (235/45/18).
Winter is on its way and I need to get some rubbers.
My options would be - get a complete set of new winter tires (rim and rubber) and get new rubber for the current rims next summer. Or, buy winter rubber for the current rims and get a new set of alloy wheels for next summer.
Which sizes fit the Kizashi, without modification to the car? 19" looks like it would fit, but how about 20"?
I'm sure I have to lower the profile if I increase the size.
Or should I just go with the same size set it has now...
Did any of this make any sense?
What sizes are you using?
Any tips and views appreciated.
I have some more ideas for it but I'll leave that for later.
Thank you.
Wheel sizes
- Sentenced1979
2011, Suzuki Kizashi SLS.
Welcome!
Someone on here posted their car with 20s on it without modification. It looked great, but like you said the profile will need to be smaller to accommodate.
I'm somewhat in the same boat as you... but I have an extra set of rims (oem 18s) that I was looking to put winter tires on them.
I most highly recommend TireRack.com
You can call and discuss your specific needs with a well-informed human; heed their advice.
(I'm downsizing my 18"s to 17X7.5" wheels, and mounting either studded Goodyears or Blizzak WS80's. Come summer I'll be able to mount less-expensive 225/50 R17 choices).
Both of those diameters will fit fine assuming you keep the rubber in the right range. The width or offset could have you running into issues if you get bold, or don't know what you're buying. The OE offset is +50 on 8's, and they mount up with about a 3/4" inset from flush at the front (which is less adjustable than the rear as we can't camber them in w/o using cammed strut bolts ($25). 9.5 wide with a +45 offset or greater should still tuck w/o pulling liners depending on the rubber you put on 'em. That should get you in the ballpark, depending on your aim.Sentenced1979 wrote:Anyway, I was wondering about the wheels...
TireRack is a good suggestion, but they will err the side of caution as they are only pulling specs from a database. (Good for staying out of trouble). If you're looking for trouble, I may have some useful data for you.
20's done tightly .. (not my rig) .. and a nice guide for rubber selection centered on our OE tire.
- Kizashi 2012 (15).jpg (177.19 KiB) Viewed 12569 times
- kizashi oem tire sizes - options.JPG (158.52 KiB) Viewed 12569 times
- Sentenced1979
Thanks for the warm welcome, everyone.
I'll check the website, maybe they could give some pointers.
I've checked online for some rims, but there are quite a few to choose from.
The size needs to be right though, like we already concluded.
I'll post again when I decide what to get.
As for the winter tires, I'll most likely go for Nokian Hakkapeliitta R2, studless tires.
Thanks again, guys.
Thanks again, guys.
CG1 wrote:Both of those diameters will fit fine assuming you keep the rubber in the right range. The width or offset could have you running into issues if you get bold, or don't know what you're buying. The OE offset is +50 on 8's, and they mount up with about a 3/4" inset from flush at the front (which is less adjustable than the rear as we can't camber them in w/o using cammed strut bolts ($25). 9.5 wide with a +45 offset or greater should still tuck w/o pulling liners depending on the rubber you put on 'em. That should get you in the ballpark, depending on your aim.Sentenced1979 wrote:Anyway, I was wondering about the wheels...
TireRack is a good suggestion, but they will err the side of caution as they are only pulling specs from a database. (Good for staying out of trouble). If you're looking for trouble, I may have some useful data for you.I have taken a ton of measurements that I couldn't find having been posted before, which will come in handy if you want to shoehorn some meat on. There are, however, a handful of dependencies that exist.
Who's car is this? Any idea of what suspension setup he's running?
Sentenced, if you're look for some more real life examples check out my build.
http://www.kizashiclub.com/forum/viewto ... f=7&t=3527
Started with 18x8 ET35 BBS CHR w/ 225/45 tire on a 2 inch drop; Later pics are with 18x10 and 18x8.5 ET38 w/ 225/45
- Sentenced1979
Thank you, sir.kconklin33 wrote:Sentenced, if you're look for some more real life examples check out my build.
That's a nice ride you got there.
Gonna try to make some time on Saturday to have a look at some rims.
Since my Kizashi is black, I don't think I'll go for all black rims. Gets to be kinda too much black, I think.
It's good to see people are still active on this forum.
I like the style of my OEM 18's. However, the paint flaking off is a major turn off. I'm debating whether to just have them professionally redone or just buying a new set of aftermarket wheels. I'm getting quotes from $90 to $125 for each wheel. Not including remounting and rebalancing
2012 Kizashi CVT AWD/ w paint chips
Orange County/Brooklyn NY
