Suzuki kuzashi 2011Sound created from fans
Rizal J
Guy
Im wondering what is the problem..noise sound appears when i start the engine when the radiator fan starts to swing. And the sound bacome louder if i switch on the air cond..anyone has this problem.
Thanks
Sent from my SM-N910C using Tapatalk
Is it a screeching noise? If so, it's your serpentine belt. It's the noise it makes when it's old in the cold. You can get a lubricant spray to quiet it down but it's a better idea to replace the serpentine belt soon. Look for small cracks on the inside of the belt. If you can see them, it's a good idea to replace it soon.
Triggerhappy
Don't start the engine, put it in accessory mode. Increase the fan speed of your climate control. Do you hear the noise? If so, it could be the blower motor going bad. I replaced mine and the noise is gone.
2018 Pacifica Hybrid - wife's
Rizal J
Tq for the info..i will take note once i bring my car to workshop
Rizal J
Rizal J
Done..and yes ..it was the motor blower..it cost me RM 500 plus labor.
Im from Kuala Lumpur Malaysia
Rizal J
Thank again Triggerhappy !
Rizal J wrote:Done..and yes ..it was the motor blower..it cost me RM 500 plus labor.
The fans in the picture are your engine cooling fans that are mounted behind the radiator. The blower motor Triggerhappy is talking about is for your heater and air conditioner and is located behind your glove box.
Regardless, glad to see it get fixed.
Triggerhappy
Yes, I was asking him to test the blower motor behind the glove box to rule it out. Glad you got the noise fixed.
Rizal J
Yes..im not good in technical stuff. Luckily i got my frienly workshop and it got fixed in less than 2 hours..im happy !
Thanks again frens..this forum help me a lot.
For your info..there are 100 units of Kizashi only in Malaysia !!
