Hi there,
I played a little bit too much with the snow this past winter and a piece of plastic is gone. I believe it would be a right fender liner if I am not mistaking. Could one of you can tell me what the part name is and possible the part # as well? I also need to know the size of the bolts on the front bumper. Thanks in advance!
Looking for a part
- FrankoLaMoya
- IMG_20160702_120605.jpg (344.55 KiB) Viewed 7091 times
- IMG_20160702_120558.jpg (200.9 KiB) Viewed 7091 times
- IMG_20160702_120551.jpg (232.17 KiB) Viewed 7091 times
http://monsterfactoryparts.com/parts/20 ... &maxRow=10
Item #4. Screws are #6. You might also be missing #7, I'm not sure if that was on all trim levels or not. I just had to change mine on the other side. The piece itself is held on by 1 screw and 3 plastic rivets, and I believe there are 2 additional screws to attach #7 to it.
Black 2011 Sport SLS AWD
- FrankoLaMoya
Thans BLyons! I thought about the shield too..not even sure yet. I'll have to take another look at the plastic rivets and screws.. I have the Sport model (2012 Canadian)
Hey guys.. I noticed I am missing a black plastic clip that is on that plastic piece above the headlight that hold it down the metal frame below it.. I was in there checking fluids .getting ready for trip to wildwood and noticed it wasn't there.. on that site for parts what is that listed under.. from what I understand you just need a screw driver to pry it up and snap it back in after you have to change the bulb. (watched the you tube video). thanks for you help
You can try to find one that fits at an auto parts store like AutoZone. It might not be exactly the same as the original clip, but if the diameter is similar, it will work just fine. It will be a lot cheaper and easier to get them in a pack from AutoZone than trying to find the specific OE clips. If you don't find something suitable in a store, you can always try to find something close enough on the site below. I've purchased from them before.pakizzie2015 wrote:Hey guys.. I noticed I am missing a black plastic clip that is on that plastic piece above the headlight that hold it down the metal frame below it.. I was in there checking fluids .getting ready for trip to wildwood and noticed it wasn't there.. on that site for parts what is that listed under.. from what I understand you just need a screw driver to pry it up and snap it back in after you have to change the bulb. (watched the you tube video). thanks for you help
http://www.clipsandfasteners.com/
Is it just the clip missing? It's common for the headlight tab to break off in that spot.
On that site, it can be found here. http://monsterfactoryparts.com/parts/20 ... per%20clip
But as Kuro said, you're probably best off seeing if you can find a pack of them, or a pack of assorted sizes so that you're covered when other ones inevitably break on the car.
