12V socket fuse size?
Hi everyone,
I don't have a Kizashi anymore but I will be helping someone hardwire their dashcam (A119) in theirs. Can someone tell me what size the fuse is for the 12V socket circuit? I'd like to know which fuse tap to purchase beforehand.
Thanks!
So you want to know the fuse type for the cigarette lighter socket? I'll check and report back later if no one else beats me to it.
KuroNekko wrote:So you want to know the fuse type for the cigarette lighter socket? I'll check and report back later if no one else beats me to it.
Yep, exactly. It's #7 and 8 according to the manual:
Fuse Diagram.pdf
(19.74 KiB) Downloaded 651 times
I suspect it's a low profile mini fuse but cannot confirm unfortunately.
Low Profile Fuse.pdf
(19.75 KiB) Downloaded 461 times
Based upon the two pdf's provided above, looks to be low profile mini without a doubt. Best to just pull it out and head off to the parts store with it if you're not convinced.
I took a photo of the actual fuse box but then later realized you probably needed me to actually pull the fuse. My bad. I can get to that this weekend, but maybe this photo I took last night can be of use.
The front accessory socket fuse is the top left-most blue 15 amp fuse. Looks to be a Mini Fuse according to your diagram.
Thank you Kuro! Looks like a low profile mini as suspected.
