Removing rear parcel to access Rockford Fosgate Sub
Don't remember any specifics about how this comes apart, I've just been telling you how they work in general. I remember that I took out the rear deck and sailed the offending part across the yard like a Frisbee, then put it back together.
Had to remove a fair amount in order to get the parcel off, also did a fair amount of cleaning - turns out the previous owner's kids were absolutely disgusting. But managed to do it.
Figured out it was the cone. Ended up contact gluing it back on - just to help protect the magnet from dust and etc. If it happens again at least I'll be able to remove everything easily and chuck the cone. But I'll leave it for now.
Thanks for the help guys, would have spent a fair amount somewhere trying to figure out what the problem was.
- stephen.louks
did you ever find the instructions to remove that partition trim? id like to get in there and try to get rid of some rattles myself.
Late reply, but sort of. Found a very basic removal guide. From memory I had to remove, not in this order, rear seats (flat seats, not back/foldable seats), c pillar, some plastic covering on either side and the arm cushions beside the door. Plus lots of screws/clips.
P.S. notice the discolouration on the bottom of the seats? It was a hundred times worse before this photo.
- _20170312_154521.JPG (231.44 KiB) Viewed 4955 times
- _20170312_153638.JPG (342.73 KiB) Viewed 4958 times
- _20170312_151848.JPG (537.11 KiB) Viewed 4959 times
