Does anyone know if a 2012 steering wheel will fit on a 2013 model ?
Is there a difference between a awd steering wheel and a non awd one ?
Can the controls from a awd model w/bluetooth fit on a non bluetooth non awd basic rim ?
Sent from my SM-T805Y using Tapatalk
Steering wheel
- SAEED_KIZZY
it's all the same I replace mine with AWD model (my car is FWD).just make sure is not RHD model.
about Bluetooth control it is possible to install in theory but not tested by me
I've you don't have cruise control (manual or CVT), adding a wheel with the controls will add cruise. If you have a CVT and want paddle shifters, adding the wheel with paddle shifters will give you paddle shifters. Alternatively, you can just branch off the wiring harness and add your own buttons.Gange wrote:If a wheel doesn't have paddle shifters on it can paddle shifters from another wheel be transplanted onto the bare wheel frame?
Can cruise /bluetooth /paddle shift controls be transferred from your wheel to a bare bones wheel that didn't have them before ?
What I mean is, if I have a basic no frills wheel from a fwd model and have it re-skinned/upgraded can I fit it to my awd sports model and fit all its controls to the new wheel ?
Paddle shifters are a CVT equipped GTS/SLS model 'thing'. That said, I wouldn't know why a no-frills steering wheel from a base S or SE wouldn't physically bolt on. No idea about if/how any other wheel mounted controls would, or wouldn't, operate. ie are the underlying harnesses different and/or any other electronic pairing issues (which ya always have to be concerned about anymore). The base steering wheel assemblies between the models would be different p/n's I'm sure. The air-bag module would likely be transferrable. I'd have to look at the parts book at home to confirm/deny my suspicions. It would also list if the wiring harnesses were different between the models.
- SAEED_KIZZY
instead of buying expensive paddle shifter from ebay I simply use 2 push button key and connect to steering wheel connector and works just fine for me.
- photo_2019-01-22_19-14-15.jpg (138.45 KiB) Viewed 8570 times
- photo_2019-01-22_19-14-09.jpg (126.8 KiB) Viewed 8570 times
