Suzuki Kizashi Clutch
808will1
Hello I have come across an issue were I have this 2012 suzuki kizashi 2.4L manual transmission car but I cant seem to find any clutch replacements online at all. I know the suzuki sx4 clutch is compatible but I cant even find a 2.4L version anywhere only the 2.0L. Can anyone help me?
The sx4 never came with the 2.4. The 2010- 13 model for the U S was fitted with the J20b . It has a bit smaller bore but nearly identical to the Kizashi and uses many of the same bolt on parts. The flywheel is the exact same but the pressure plate and clutch disc are smaller . This clutch kit is widely available and can be used in the Kizashi if you need the works. If all is still nice condition and you just want to slip in a new proper size disc, a 1990 Mitsubishi Eclipse uses the same shaft spline and diameter and has been done before.
yadi99
Hello there thanks for the info, i am having this same issue finding a clutch for my 2011 Kizashi S, if i am reading correctly the pressure plate and disc from a 1990 Eclipse should fit then so thats what i should purchase?
yadi99 wrote: Thu Nov 14, 2024 5:48 am Hello there thanks for the info, i am having this same issue finding a clutch for my 2011 Kizashi S, if i am reading correctly the pressure plate and disc from a 1990 Eclipse should fit then so thats what i should purchase?
Only the disc and it being aftermarket, you will have to compare all angles.
