Trust me when i say it looks even better in real life! The 6000k HID's and led's at night are a perfect match in terms of color but in the pics they look different.
Basically all you need is some side shining led strips like these
http://cgi.ebay.com/ebaymotors/WHITE-12 ... ccessories
and some wire to hook everything up. I bought about 30 feet of wiring since it was cheap. Don't need anything too thick as it's just led's.
Step 1. Test the LED's first! Each LED strip has 2 wires, make sure you connect 1 wire to the positive terminal on the battery and the other wire to a ground ( i chose the bolt in the picture below ) If they dont work switch them around to see which wire is the ground and which isn't.
I made the mistake of only testing 1 led strip and when i put the bumper back on and was done, one of them didnt work. My led's had a copper and a silver wire, after testing only 1 led i assumed the copper was the ground and silver was the positive but both strips were different so test them both.
Step 2. Take the front bumper off. ( I will take pics soon to show you how it's done ) If you look up one of the DIY hid's guides on the forum you can see how it's done also.
Step 3.
Clean the surface where you will stick the led strips. After some testing i think they looked best on the 2nd grill thing. Below i nthe pic where i put the yellow lines there are cuts in the grill where the wiring can go through.
Step 4. Stick the led strips on
Step 5. Time to do the wiring, to minimise wiring this is probably the easiest way below. I had to do my wiring a tiny bit different because after 1 led didn't work it was a pain in the ass to troubleshoot and get it to work.
You basically join the negatives from each led together, then join the positives together as shown by the purple wire below. Once that is done you should attach about 4-5 feet ( to be sure ) of wiring to the points below as shown with the green wire.
To keep the wires tidy behind the bumper i found these little clip things where i could put the wires through so they dont hang down. I also used shrink tube wherever i joined wires together so it looks professional.
Step 6. Put the bumper back on but before you do make sure the 2 wires you have ( 4-5 feet long ) are passed under the headlight and into the engine bay near where your battery is and maybe tie them so they dont fall through as you put your bumper back on. Figure out a way so you can tell which wire should be grounded and which should be connected to the fuse.
Step 7. I connected the wire to be grounded to a bolt on the chassis as shown in one of the pictures, and i used a terminal ring so it looks more professional.
The other wire i connected to the fuse #33 in the engine bay which is the rear defogger relay. Thankyou to KCkizashi off the forums for this!
All i did was strip the wire about 3/4 - 1 inch and wrapped it around the pin on the fuse that is closest to the firewall. So imagine you are putting the fuse back in and look at which pin is closest to the firewall. This way the led's turn on when the car is on and automatically off when the car is off.
That should be it. Let me know if you have any questions. I will take some detailed photos about getting the front bumper off.
