Help with installing rear brakes
John_1976
I need a little help with the rear brakes on a 2010 S model. Need to replace after 41,000 miles and this particular design seems to be a little different that others I have worked on before. Need a little insight with someone who has replaced the rear pads before. Thanks in advance.
puckaveli
give me your email and i'll send you the service manual section for the rear brakes.
2000 Subaru Impreza 2.5RS
2013 Suzuki Kizashi GTS AWD
2006 Kawaski 636
jute2003
what's different about it? I just checked the pads all the way around on my car but didn't look to closely at anything. 39,000 and lots of pad left for me
nytq
Hope this helps.
178331019.pdf
(47.66 KiB) Downloaded 1692 times
178331020.pdf
(112.98 KiB) Downloaded 1291 times
178331020pdf.pdf
(81.31 KiB) Downloaded 1219 times
178331021.pdf
(113.39 KiB) Downloaded 1100 times
178331022.pdf
(115.13 KiB) Downloaded 1204 times
178331023.pdf
(66.06 KiB) Downloaded 1094 times
178331024.pdf
(107.9 KiB) Downloaded 1125 times
178331025.pdf
(114.5 KiB) Downloaded 1056 times
178331026.pdf
(83.29 KiB) Downloaded 1114 times
178331027.pdf
(115.08 KiB) Downloaded 1139 times
ALLDATAdiy.com - 2011 Suzuki Kizashi AWD L4-2.pdf
(469.94 KiB) Downloaded 1558 times
John_1976
Thank you all, email address is jjpach2001nospam@yahoo.com. Had the car in for state inspection (WV) several days ago and the mechanic said the outer pad was worn almost to the point of failing the inspection. Other than this, it has been an amazing car.
something else may be wrong to cause a single pad to wear that badly. I have nearly 30,000 miles and my pads all look nearly brand new. I'll easily get another 30k out of them.
John_1976
Just got them replaced this afternoon. Outer pad paper thin, inner pad about 25% left. Calipers don't seem to be sticking to indicate a problem so we will see how long the replacements last (Wagner Gold). FYI once you relieve the tension on the park brake cable at the handle end, the cable does not have to be taken off of the caliper as the service manual states.
delusional29
What about the rotors? I can't seem to figure out which bolts to remove. (On the front it was easy).
D
