Help with installing rear brakes
I need a little help with the rear brakes on a 2010 S model. Need to replace after 41,000 miles and this particular design seems to be a little different that others I have worked on before. Need a little insight with someone who has replaced the rear pads before. Thanks in advance.
Hope this helps.
- 178331019.pdf
- (47.66 KiB) Downloaded 1688 times
- 178331020.pdf
- (112.98 KiB) Downloaded 1287 times
- 178331020pdf.pdf
- (81.31 KiB) Downloaded 1216 times
- 178331021.pdf
- (113.39 KiB) Downloaded 1098 times
- 178331022.pdf
- (115.13 KiB) Downloaded 1201 times
- 178331023.pdf
- (66.06 KiB) Downloaded 1091 times
- 178331024.pdf
- (107.9 KiB) Downloaded 1122 times
- 178331025.pdf
- (114.5 KiB) Downloaded 1054 times
- 178331026.pdf
- (83.29 KiB) Downloaded 1112 times
- 178331027.pdf
- (115.08 KiB) Downloaded 1135 times
- ALLDATAdiy.com - 2011 Suzuki Kizashi AWD L4-2.pdf
- (469.94 KiB) Downloaded 1553 times
Thank you all, email address is jjpach2001nospam@yahoo.com. Had the car in for state inspection (WV) several days ago and the mechanic said the outer pad was worn almost to the point of failing the inspection. Other than this, it has been an amazing car.
something else may be wrong to cause a single pad to wear that badly. I have nearly 30,000 miles and my pads all look nearly brand new. I'll easily get another 30k out of them.
Just got them replaced this afternoon. Outer pad paper thin, inner pad about 25% left. Calipers don't seem to be sticking to indicate a problem so we will see how long the replacements last (Wagner Gold). FYI once you relieve the tension on the park brake cable at the handle end, the cable does not have to be taken off of the caliper as the service manual states.
- delusional29
What about the rotors? I can't seem to figure out which bolts to remove. (On the front it was easy).
D
D
